Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
In order to replace to On/Off switch, you will once again have to take apart the whole unit to get to that part.
Wat je nodig hebt
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
To reassemble your device, follow these instructions in reverse order. It will look like the faceplate is still bent out, but after you put the screws back in it will come back into place.
