Inleiding
If the toaster door does not stay shut, heat will escape and the toaster will not work properly. This problem can be solved by simply replacing the door spring mechanism.
Wat je nodig hebt
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
Hi I am doing my own repairs on a black and decker toaster oven and need some help. identifying that part under the oven where the power cord enters the enclosure its actually a disconnect switch to disconnect the power when the door is opened.
Use the screwdriver to remove the spring from the unit.
Place the screwdriver inside the spring loop.
Pull to unhinge the spring from the back panel.
2 opmerkingen
Great guide! Very clearly-written and accompanying photos captured the process effectively.
