Ga door naar hoofdinhoud
Black and Decker TR1278B Lever Catch-Spring Replacement
Wat je nodig hebt
  1. Black and Decker TR1278B Lever Catch-Spring Replacement, Top Cover: stap 1, afbeelding 1 van 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Lever Catch-Spring Replacement: stap 2, afbeelding 1 van 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Lever Catch-Spring Replacement: stap 3, afbeelding 1 van 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Lever Catch-Spring Replacement: stap 4, afbeelding 1 van 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Lever Catch-Spring Replacement: stap 5, afbeelding 1 van 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. Black and Decker TR1278B Lever Catch-Spring Replacement, Lever Catch Spring: stap 6, afbeelding 1 van 1
    • Lift the top cover up and remove it from the toaster.
  7. Black and Decker TR1278B Lever Catch-Spring Replacement: stap 7, afbeelding 1 van 1
    • Locate the springs.
    • There is a top spring and bottom spring.
  8. Black and Decker TR1278B Lever Catch-Spring Replacement: stap 8, afbeelding 1 van 2 Black and Decker TR1278B Lever Catch-Spring Replacement: stap 8, afbeelding 2 van 2
    • Use needle nose tweezers to free one end of the spring.
    • Turn the spring until it is completely free.
  9. Black and Decker TR1278B Lever Catch-Spring Replacement: stap 9, afbeelding 1 van 1
    • Remove spring for replacement.
    • Repeat steps for bottom spring.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brea-Monique
351 Reputatie
3 handleidingen geschreven
USF Tampa, Team 8-1, Eyestone Spring 2017 Lid van USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
3 Leden
5 handleidingen geschreven
Één opmerking
Hi there, thanks for this guide. I have a little issue : one of the screws is quite unusual, probably because it’s not meant to be repaired by a poor peasant. It has a little pin in it and I can’t unscrew it with the tools I have. Any tips ?
ToasterMaster - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 1,294
