Ga door naar hoofdinhoud
Black and Decker TR1278B Bread Grabber Spring Replacement
Wat je nodig hebt
  1. Black and Decker TR1278B Bread Grabber Spring Replacement, Top Cover: stap 1, afbeelding 1 van 1
    • Unplug the toaster before disassembly.
    • Remove the carriage lever by pulling it away from the toaster.
  2. Black and Decker TR1278B Bread Grabber Spring Replacement: stap 2, afbeelding 1 van 1
    • Toaster will be turned upside down. Clear crumb tray or work over a paper towel.
    • Turn the toaster upside down.
    • Unscrew all four 4mm screws on the bottom using a Phillip's head #2 (PH2) screwdriver.
    • Or a slightly different model has six screws that require an allen wrench (hex key). Ones that have a ball end will not work. I had to use one that had more of a Star of David, pointy pattern to it.
  3. Black and Decker TR1278B Bread Grabber Spring Replacement: stap 3, afbeelding 1 van 1
    • Detach the bottom from the front cover using the plastic opening tool.
  4. Black and Decker TR1278B Bread Grabber Spring Replacement: stap 4, afbeelding 1 van 1
    • Turn the toaster right side up.
    • Support the bottom. The ribbon cable that connects the toaster to the front cover can be damaged.
    • Lift the front cover.
    • Lift carefully. Again the ribbon cable can be damaged.
  5. Black and Decker TR1278B Bread Grabber Spring Replacement: stap 5, afbeelding 1 van 1
    • Detach the bundled cable connector from the toaster by carefully pulling it away from the circuit board.
  6. Black and Decker TR1278B Bread Grabber Spring Replacement, Bread Grabber Spring: stap 6, afbeelding 1 van 1
    • Locate the spring
  7. Black and Decker TR1278B Bread Grabber Spring Replacement: stap 7, afbeelding 1 van 1
    • Press down on the toaster lever to gain access to the grabber spring located behind the large metal plate.
    • Use metal spudger to loosen clamps on spring.
  8. Black and Decker TR1278B Bread Grabber Spring Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use needle nose tweezers to pull the spring off of its hook.
    • Repeat this step for the opposite side.
  9. Black and Decker TR1278B Bread Grabber Spring Replacement: stap 9, afbeelding 1 van 1
    • Remove the old spring from the toaster unit to insert the new one.
Conclusie
Brea-Monique
399 Reputatie
3 handleidingen geschreven
USF Tampa, Team 8-1, Eyestone Spring 2017 Lid van USF Tampa, Team 8-1, Eyestone Spring 2017
USFT-EYESTONE-S17S8G1
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 35
Altijd: 1,264
