Ga door naar hoofdinhoud
Black and Decker Pivot MAX Battery Replacement
Wat je nodig hebt
  1. Black and Decker Pivot MAX Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Black and Decker Pivot MAX Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Battery Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Battery Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
Conclusie
25 andere personen hebben deze handleiding voltooid.
Jesse Sipes
586 Reputatie
2 handleidingen geschreven
IUPUI, Team S5-G6, Baechle Fall 2017 Lid van IUPUI, Team S5-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G6
3 Leden
5 handleidingen geschreven
27 opmerkingen
any idea where to find the replacement battery? Does it come as a unit or do you need to disassemble the battery pack and replace the cells?
DMcDermott - Antwoord
Where do I get the cells to replace the old ones?
Patricia Leat - Antwoord
How do you disconnect the quick connect
DJ SmashBeatz - Antwoord
My battery pack is soldered to a circuit board. There is no quick connect. (Model BDH2000PL, Type 2).
HBL - Antwoord
Same here. Worst design ever.
James Watson -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 163
Afgelopen 30 dagen: 710
Altijd: 44,905
