Inleiding
This guide is to replace the Lithium Ion battery located in the main body of the Black and Decker Pivot Max. No special tools are necessary, only a phillips screw driver is needed for this replacement.
Wat je nodig hebt
Press in and hold the release button.
Rotate the dust filter chamber counter-clockwise.
Remove the dust filter chamber.
25 andere personen hebben deze handleiding voltooid.
27 opmerkingen
any idea where to find the replacement battery? Does it come as a unit or do you need to disassemble the battery pack and replace the cells?
Where do I get the cells to replace the old ones?
How do you disconnect the quick connect
My battery pack is soldered to a circuit board. There is no quick connect. (Model BDH2000PL, Type 2).
Same here. Worst design ever.
