Ga door naar hoofdinhoud
Black and Decker PVH1810 Hand Vac Battery Replacement
Wat je nodig hebt
  1. Black and Decker PVH1810 Hand Vac Battery Replacement, Nozzle, Filter, and Catch Bowl: stap 1, afbeelding 1 van 2 Black and Decker PVH1810 Hand Vac Battery Replacement, Nozzle, Filter, and Catch Bowl: stap 1, afbeelding 2 van 2
    • To take off the nozzle, filter, and catch bowl first start off by pushing in the button identified with a red square and twist that part of the device toward the handle portion of the vacuum and it should click and pop off the chassis.
  2. Black and Decker PVH1810 Hand Vac Battery Replacement: stap 2, afbeelding 1 van 2 Black and Decker PVH1810 Hand Vac Battery Replacement: stap 2, afbeelding 2 van 2
    • Once the nozzle, filter and dust bowl have been removed each part can be removed from the nozzle section of the device.
  3. Black and Decker PVH1810 Hand Vac Battery Replacement, Motor: stap 3, afbeelding 1 van 2 Black and Decker PVH1810 Hand Vac Battery Replacement, Motor: stap 3, afbeelding 2 van 2
    • Remove the three screws.
  4. Black and Decker PVH1810 Hand Vac Battery Replacement: stap 4, afbeelding 1 van 2 Black and Decker PVH1810 Hand Vac Battery Replacement: stap 4, afbeelding 2 van 2
    • Flip the hand vac over and remove two screws.
  5. Black and Decker PVH1810 Hand Vac Battery Replacement: stap 5, afbeelding 1 van 3 Black and Decker PVH1810 Hand Vac Battery Replacement: stap 5, afbeelding 2 van 3 Black and Decker PVH1810 Hand Vac Battery Replacement: stap 5, afbeelding 3 van 3
    • Once you have successfully unscrewed the five screws holding the cover on you should be able to take the cover off.
    • Remove the L-shaped plastic hook.
    • Once the L shaped hook has been removed the motor will easily fall out of place.
    • Once the motor has been removed from its home the two wires that are giving it power can easily be removed by pulling on them carefully.
    • This will then allow for you to replace the motor.
  6. Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: stap 7, afbeelding 1 van 3 Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: stap 7, afbeelding 2 van 3 Black and Decker PVH1810 Hand Vac Battery Replacement, Battery: stap 7, afbeelding 3 van 3
    • Remove the three screws highlighted with red circles.
  7. Black and Decker PVH1810 Hand Vac Battery Replacement: stap 8, afbeelding 1 van 2 Black and Decker PVH1810 Hand Vac Battery Replacement: stap 8, afbeelding 2 van 2
    • Remove the battery by pulling it out of the slot it sits in.
Conclusie
7 andere personen hebben deze handleiding voltooid.
12 opmerkingen
Where can I get a replacement battery?
Lisa - Antwoord
Anyone? Good place to order a replacement?
Brad - Antwoord
“Remove the battery” sounds pretty simple, but my pivot vac seems to be “hard-connected” to the battery terminal, and I haven’t a clue where to go from here (though the trash heap—and recycling center—are strong candidates). Mine is an older model (2012) and perhaps that explains why these otherwise excellent instructions lead me to a dead-end.
Jim 4/14/21
James Bonner - Antwoord
Agree. I dissembled down to this last photo, but the battery won’t budge.
MJ Waz - Antwoord
the gray handle on one side pops open if you pry at it and there are screws underneath.
Matt Whats -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 137
Altijd: 6,766
