Ga door naar hoofdinhoud
Black and Decker LI2000 Battery Replacement
Wat je nodig hebt
  1. Black and Decker LI2000 Battery Replacement, Orange Casing: stap 1, afbeelding 1 van 3 Black and Decker LI2000 Battery Replacement, Orange Casing: stap 1, afbeelding 2 van 3 Black and Decker LI2000 Battery Replacement, Orange Casing: stap 1, afbeelding 3 van 3
    • Remove the following five screws
    • Three 20 mm Phillips #1 screws
    • One 10 mm #000 Phillips screw
    • One 13 mm Phillips 31 screw
    • When you remove the 13 mm screw, the spring may pop out of the screwdriver. Point the backside of the screwdriver away from your face and others.
  2. Black and Decker LI2000 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the black sticker with recycling information.
  3. Black and Decker LI2000 Battery Replacement: stap 3, afbeelding 1 van 1
    • Use your fingers or a plastic opening tool to pry the casing apart.
  4. Black and Decker LI2000 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the plastic slider by picking it up off the screwdriver.
    • You may consider leaving half of the casing on the screwdriver to make handling the screwdriver easier.
  5. Black and Decker LI2000 Battery Replacement, Handle: stap 5, afbeelding 1 van 2 Black and Decker LI2000 Battery Replacement, Handle: stap 5, afbeelding 2 van 2
    • Remove the four 15mm Phillips #1 screws.
  6. Black and Decker LI2000 Battery Replacement: stap 6, afbeelding 1 van 2 Black and Decker LI2000 Battery Replacement: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool to pry the casing apart.
  7. Black and Decker LI2000 Battery Replacement, Battery: stap 7, afbeelding 1 van 2 Black and Decker LI2000 Battery Replacement, Battery: stap 7, afbeelding 2 van 2
    • Using pliers or your fingers, remove the leads off of the battery.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Katherine Simmons
732 Reputatie
5 handleidingen geschreven
IUPUI, Team 1-3, Baechle Spring 2016 Lid van IUPUI, Team 1-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G3
4 Leden
10 handleidingen geschreven
3 opmerkingen
It would be great is you could discuss the 3.6v cell - Lithium Type -- Size? Is it an 18650?
William Tzouris - Antwoord
OK, so where can we get the battery!?
Mike Young - Antwoord
Check eBay for the 18650 with solder tabs already attached. I purchased a 4 pack of the batteries and used 1 for a LI3100. I needed a Dremel tool to remove some of the internal plastic battery supports to accommodate this battery. If the solder tabs had been oriented 180 degrees to each other, it would have been a drop in fit. Screwdriver works great now!
Jeff McDermaid - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 43
Altijd: 9,216
