Ga door naar hoofdinhoud
Black and Decker LDX172C Trigger Switch Replacement
Wat je nodig hebt
  1. Black and Decker LDX172C Trigger Switch Replacement, Trigger Switch: stap 1, afbeelding 1 van 1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Trigger Switch Replacement: stap 2, afbeelding 1 van 1
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Trigger Switch Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
  4. Black and Decker LDX172C Trigger Switch Replacement: stap 4, afbeelding 1 van 3 Black and Decker LDX172C Trigger Switch Replacement: stap 4, afbeelding 2 van 3 Black and Decker LDX172C Trigger Switch Replacement: stap 4, afbeelding 3 van 3
    • Remove trigger from drill by pulling the mechanism directly up off the holding pins.
    • The leads from the switch are removed by using a heating the solder until they come free.
    • Re-solder the leads to the new switch.
    • Repeat directions in reverse to reassemble.
Conclusie
jakebontragersinger
173 Reputatie
1 Handleiding geschreven
IUPUI, Team 3-3, Wilson Spring 2016 Lid van IUPUI, Team 3-3, Wilson Spring 2016
IUPUI-WILSON-S16S3G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 3,324
