Ga door naar hoofdinhoud
Black and Decker LDX172C Battery Charge Port Replacement
Wat je nodig hebt
  1. Black and Decker LDX172C Battery Charge Port Replacement, Battery Charge Port: stap 1, afbeelding 1 van 1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Battery Charge Port Replacement: stap 2, afbeelding 1 van 1
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Battery Charge Port Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the battery charging port in the base of the drill.
  4. Black and Decker LDX172C Battery Charge Port Replacement: stap 4, afbeelding 1 van 1
    • Remember that the battery may still have a charge. To avoid electrical shock, it is a good idea to disconnect the battery before modifying any connections on the charging port. You can find how to disconnect the battery here
    • Remove the soldered wire connections as marked.
    • Re-solder the wire connections to the new charge port and insert the charge port back into its proper location.
    • Repeat steps in reverse to reassemble.
Conclusie
Eric Miessen
182 Reputatie
1 Handleiding geschreven
IUPUI, Team 3-3, Wilson Spring 2016 Lid van IUPUI, Team 3-3, Wilson Spring 2016
IUPUI-WILSON-S16S3G3
4 Leden
6 handleidingen geschreven
Één opmerking
Hi where can I get the replacement charge port from. Thanks
adam mellor - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 29
Altijd: 2,533
