Ga door naar hoofdinhoud
Black and Decker LDX 120C Gear Replacement
Wat je nodig hebt
  1. Black and Decker LDX 120C Gear  Replacement, Outer Case: stap 1, afbeelding 1 van 1
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Black and Decker LDX 120C Gear  Replacement: stap 2, afbeelding 1 van 1
    • Remove the four screws on the back top side of the drill.
  3. Black and Decker LDX 120C Gear  Replacement: stap 3, afbeelding 1 van 1
    • Remove the four screws that connect the chuck to the drill.
  4. Black and Decker LDX 120C Gear  Replacement: stap 4, afbeelding 1 van 1
    • Remove the five screws on the front side of the drill.
  5. Black and Decker LDX 120C Gear  Replacement: stap 5, afbeelding 1 van 1
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. Black and Decker LDX 120C Gear  Replacement: stap 6, afbeelding 1 van 1
    • At this point you should be able to separate both as illustrated.
  7. Black and Decker LDX 120C Gear  Replacement: stap 7, afbeelding 1 van 1
    • Now all the components of the drill are visible and can be accessed.
  8. Black and Decker LDX 120C Gear  Replacement, Gear: stap 8, afbeelding 1 van 1
    • After following the prerequisite guide you will be able to access the interior components of the drill.
  9. Black and Decker LDX 120C Gear  Replacement: stap 9, afbeelding 1 van 1
    • Gently remove the top part (motor and chuck) from the rest of the drill.
  10. Black and Decker LDX 120C Gear  Replacement: stap 10, afbeelding 1 van 1
    • Make sure you do that with care so that the connection doesn't get damaged.
  11. Black and Decker LDX 120C Gear  Replacement: stap 11, afbeelding 1 van 1
    • To be able to get into the gears you will need to separate the motor from the rest.
    • And then you will be able to access the gears which is located between the motor and the chuck.
  12. Black and Decker LDX 120C Gear  Replacement: stap 12, afbeelding 1 van 1
    • Twist the gauge to change between the gear.
    • If you don't hear a clicking sound then check the gears.
  13. Black and Decker LDX 120C Gear  Replacement: stap 13, afbeelding 1 van 1
    • Twist the gear and see if the three gears rotate without jamming.
  14. Black and Decker LDX 120C Gear  Replacement: stap 14, afbeelding 1 van 1
    • Check if any gear is chipped or broken in any way.
    • If it is then you will need to change the broken gear.
  15. Black and Decker LDX 120C Gear  Replacement: stap 15, afbeelding 1 van 1
    • Using the spudger place it under the gear as illustrated.
  16. Black and Decker LDX 120C Gear  Replacement: stap 16, afbeelding 1 van 1
    • The gear will remove with just a little amount of force.
  17. Black and Decker LDX 120C Gear  Replacement: stap 17, afbeelding 1 van 1
    • The gear has been removed and now can be replaced by another gear.
Conclusie
jeffrey zakka
735 Reputatie
6 handleidingen geschreven
USF Tampa, Team 11-5, Cheng Spring 2016 Lid van USF Tampa, Team 11-5, Cheng Spring 2016
USFT-CHENG-S16S11G5
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 33
Altijd: 1,977
