Inleiding
This guide will teach the user to replace the gearbox. The gearbox is what converts the energy of the motor into the cutting power of the saw. It looks to be hard to replace because there are many stacked metal plates covered in grease, but there is a central pin that keeps it all together. Sometimes the only fix needed is to add more grease to the gearbox.
Wat je nodig hebt
Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
Being careful to keep all parts together, grab the entire assembly and pull it directly out of the saw.
Remove the two 30.1625mm screws with a T20 torx screwdriver that are holding the gearbox to the housing.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Hi. Can you please describe how to replace motor for BELTSANDER. Thanks. Chris
