Ga door naar hoofdinhoud
Black and Decker JS660 Gear Box Replacement
Wat je nodig hebt
  1. Black and Decker JS660 Gear Box Replacement, Housing Disassembly: stap 1, afbeelding 1 van 2 Black and Decker JS660 Gear Box Replacement, Housing Disassembly: stap 1, afbeelding 2 van 2
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Gear Box Replacement: stap 2, afbeelding 1 van 1
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Gear Box Replacement, Blade Holder: stap 3, afbeelding 1 van 1
    • Being careful to keep all parts together, grab the entire assembly and pull it directly out of the saw.
  4. Black and Decker JS660 Gear Box Replacement, Motor: stap 4, afbeelding 1 van 1
    • Remove the two 30.1625mm screws with a T20 torx screwdriver that are holding the gearbox to the housing.
  5. Black and Decker JS660 Gear Box Replacement: stap 5, afbeelding 1 van 1
    • Apply a light force to separate the gearbox from the housing. This will momentarily separate the gearbox and help with the removal of the system in later steps.
  6. Black and Decker JS660 Gear Box Replacement: stap 6, afbeelding 1 van 2 Black and Decker JS660 Gear Box Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers or a small flathead screwdriver, gently remove each of the black magnetic clasps away from the motor.
  7. Black and Decker JS660 Gear Box Replacement: stap 7, afbeelding 1 van 1
    • Holding the gearbox and the bering, pull the whole motor and gearbox out of the housing.
  8. Black and Decker JS660 Gear Box Replacement: stap 8, afbeelding 1 van 1
    • While holding the motor in one hand, gently pull the gearbox off of the drive shaft.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
matt murray
682 Reputatie
6 handleidingen geschreven
Cal Poly, Team 22-9, Maness Winter 2017 Lid van Cal Poly, Team 22-9, Maness Winter 2017
CPSU-MANESS-W17S22G9
4 Leden
7 handleidingen geschreven
Één opmerking
Hi. Can you please describe how to replace motor for BELTSANDER. Thanks. Chris
Chris Breedt - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 21
Altijd: 1,618
