Inleiding
This guide will take you through the process of replacing the switch on the Black and Decker BV2500 Type 4.
Wat je nodig hebt
Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver.
Using your hands, lift off side of the orange casing with the screws facing you.
Bijna klaar!
Conclusie
