Ga door naar hoofdinhoud
Black and Decker BV2500 Type 4 Switch Replacement
Wat je nodig hebt
  1. Black and Decker BV2500 Type 4 Switch Replacement, Clamshell (Black Outer Casing): stap 1, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Switch Replacement: stap 2, afbeelding 1 van 2 Black and Decker BV2500 Type 4 Switch Replacement: stap 2, afbeelding 2 van 2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Switch Replacement, Switch: stap 3, afbeelding 1 van 2 Black and Decker BV2500 Type 4 Switch Replacement, Switch: stap 3, afbeelding 2 van 2
    • Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver.
    • Using your hands, lift off side of the orange casing with the screws facing you.
  4. Black and Decker BV2500 Type 4 Switch Replacement: stap 4, afbeelding 1 van 3 Black and Decker BV2500 Type 4 Switch Replacement: stap 4, afbeelding 2 van 3 Black and Decker BV2500 Type 4 Switch Replacement: stap 4, afbeelding 3 van 3
    • Locate the switch on the handle of the blower.
    • Carefully remove the four wires that are attached to the switch.
    • Use your hand to push in the sides of the switch and slide out the wires.
  5. Black and Decker BV2500 Type 4 Switch Replacement: stap 5, afbeelding 1 van 1
    • Note for reassembly: Be sure to put this back the way it was found.
Conclusie
Jon Gori
137 Reputatie
1 Handleiding geschreven
Cal Poly, Team 9-29, Maness Winter 2014 Lid van Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 3,421
