Ga door naar hoofdinhoud
Black and Decker BV2500 Type 4 Power Cord Replacement
Wat je nodig hebt
  1. Black and Decker BV2500 Type 4 Power Cord Replacement, Clamshell (Black Outer Casing): stap 1, afbeelding 1 van 1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Power Cord Replacement: stap 2, afbeelding 1 van 2 Black and Decker BV2500 Type 4 Power Cord Replacement: stap 2, afbeelding 2 van 2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Power Cord Replacement, Power Cord: stap 3, afbeelding 1 van 2 Black and Decker BV2500 Type 4 Power Cord Replacement, Power Cord: stap 3, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove the ten 20 mm screws in the orange casing.
    • Use your hands to lift off the side of the orange casing with the screws facing you.
  4. Black and Decker BV2500 Type 4 Power Cord Replacement: stap 4, afbeelding 1 van 2 Black and Decker BV2500 Type 4 Power Cord Replacement: stap 4, afbeelding 2 van 2
    • Locate the switch.
    • Remove the 2 black and white wires with blue casings from the switch.
    • Using your hands, push in the sides of the switch and slide out the wires.
  5. Black and Decker BV2500 Type 4 Power Cord Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 20 mm Phillips #2 screws that are holding in the power cord (located at the bottom of the leaf hog).
  6. Black and Decker BV2500 Type 4 Power Cord Replacement: stap 6, afbeelding 1 van 3 Black and Decker BV2500 Type 4 Power Cord Replacement: stap 6, afbeelding 2 van 3 Black and Decker BV2500 Type 4 Power Cord Replacement: stap 6, afbeelding 3 van 3
    • Slide the power cord support off the power cord in the direction of the leads.
    • Use your hands to pull the power cord out of the device with the lead end coming out last.
Conclusie
Angelica Chow
409 Reputatie
3 handleidingen geschreven
Cal Poly, Team 9-29, Maness Winter 2014 Lid van Cal Poly, Team 9-29, Maness Winter 2014
CPSU-MANESS-W14S9G29
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 3,561
