Ga door naar hoofdinhoud
Black and Decker BL3000S Motor Fan Replacement
Wat je nodig hebt
  1. Black and Decker BL3000S Motor Fan Replacement, Blender Base: stap 1, afbeelding 1 van 2 Black and Decker BL3000S Motor Fan Replacement, Blender Base: stap 1, afbeelding 2 van 2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S Motor Fan Replacement: stap 2, afbeelding 1 van 1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S Motor Fan Replacement: stap 3, afbeelding 1 van 2 Black and Decker BL3000S Motor Fan Replacement: stap 3, afbeelding 2 van 2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S Motor Fan Replacement: stap 4, afbeelding 1 van 1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S Motor Fan Replacement: stap 5, afbeelding 1 van 1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S Motor Fan Replacement, Motor Fan: stap 6, afbeelding 1 van 2 Black and Decker BL3000S Motor Fan Replacement, Motor Fan: stap 6, afbeelding 2 van 2
    • Using pliers, remove the top nut from the fan and remove the washer.
    • Use a small towel to hold the fan in place. This makes taking off the nut easier to do.
  7. Black and Decker BL3000S Motor Fan Replacement: stap 7, afbeelding 1 van 1
    • Lift the fan blades from the blender base.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Andrew
209 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-34, Regan Fall 2012 Lid van Cal Poly, Team 6-34, Regan Fall 2012
CPSU-REGAN-F12S6G34
4 Leden
6 handleidingen geschreven
Één opmerking
mon mixeur a montre des itincelles et de la fumeé quel étape puis suivre pour le réparer
abdelkarim hassi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 56
Altijd: 4,443
