Ga door naar hoofdinhoud
Black and Decker BDEDMT Power Cord Replacement
Wat je nodig hebt
  1. Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: stap 1, afbeelding 1 van 2 Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: stap 1, afbeelding 2 van 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: stap 2, afbeelding 1 van 3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: stap 2, afbeelding 2 van 3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: stap 2, afbeelding 3 van 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: stap 3, afbeelding 1 van 2 Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: stap 3, afbeelding 2 van 2
    • Using the T-handle screwdriver with the JIS 1 bit, unscrew the two lower black 12mm screws.
  4. Black and Decker BDEDMT Power Cord Replacement: stap 4, afbeelding 1 van 2 Black and Decker BDEDMT Power Cord Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  5. Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: stap 5, afbeelding 1 van 2 Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: stap 5, afbeelding 2 van 2
    • Physically pull up on the trigger device and remove it from the armature.
    • Flip trigger device over onto its back.
  6. Black and Decker BDEDMT Power Cord Replacement, Wire Removal: stap 6, afbeelding 1 van 3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: stap 6, afbeelding 2 van 3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: stap 6, afbeelding 3 van 3
    • There is a screw labeled 3 located on the bottom left of the back of the trigger device.
    • Use a JIS 0 screwdriver to remove screw.
    • Gently tug on the black wire to pull the wire out of the device.
    • Now the power cord will be completely removed from the device.
Conclusie
cayla dahl
247 Reputatie
2 handleidingen geschreven
UW Tacoma, Team 1-2, Rose Winter 2016 Lid van UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 33
Altijd: 2,177
