Ga door naar hoofdinhoud
Black and Decker BDEDMT Motor Replacement
Wat je nodig hebt
  1. Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: stap 1, afbeelding 1 van 2 Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: stap 1, afbeelding 2 van 2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: stap 2, afbeelding 1 van 3 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: stap 2, afbeelding 2 van 3 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: stap 2, afbeelding 3 van 3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Motor Replacement, Motor: stap 3, afbeelding 1 van 1
    • Gently pull up the motor and other components at the top of the device except the handle.
    • Watch out for the wires. They are connected to two compressed magnets in the black framework.
  4. Black and Decker BDEDMT Motor Replacement: stap 4, afbeelding 1 van 2 Black and Decker BDEDMT Motor Replacement: stap 4, afbeelding 2 van 2
    • Slide off the the black framework on the barring side.
    • You may have to compress the magnets in order to slide the framework off of the barring.
  5. Black and Decker BDEDMT Motor Replacement: stap 5, afbeelding 1 van 2 Black and Decker BDEDMT Motor Replacement: stap 5, afbeelding 2 van 2
    • Remove the release button attached at the front of the motor.
    • It may have already come off during Step 3.
  6. Black and Decker BDEDMT Motor Replacement: stap 6, afbeelding 1 van 2 Black and Decker BDEDMT Motor Replacement: stap 6, afbeelding 2 van 2
    • Work the silver magnetic ring off of the motor through the barring end.
    • The motor is now free.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyler Yurina
419 Reputatie
2 handleidingen geschreven
UW Tacoma, Team 1-2, Rose Winter 2016 Lid van UW Tacoma, Team 1-2, Rose Winter 2016
UWT-ROSE-W16S1G2
4 Leden
11 handleidingen geschreven
3 opmerkingen
Hi,
Please can you tell me where to find the motor replacement part for this tool?
Thank you
Renato - Antwoord
I have this tool and the attachments and I absolutely love it…but I'm pretty sure the gears are stripped…do you know anything about replacing those?
cwilson0713@gmail.com - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 64
Altijd: 2,780
