Inleiding
I only like to use electric screwdrivers for the assembly of larger screws from larger components. This one has been used on many TV's and Radio's and just did not hold a charge any longer. I decided to get a new battery and replace the old one. Fairly easy and straight forward task. The biggest problem with this job was to find a new battery.
Wat je nodig hebt
Black & Decker 9074 type 4 screwdriver that no longer holds a charge.
Main pieces to work on for disassembly
Remove the clip that holds the transmission to the body. Insert a 6mm (1/4") flat tip screwdriver underneath the clip, gently move clip upward.
9 andere personen hebben deze handleiding voltooid.
2 opmerkingen
thanks. It is also useful for old TYPE 1 model 9018. But where can you find the battery?
Biller koby of course like so many other things, the battery is no longer available. But we have a fix for that as well. Check this guide Black and Decker 9074 schroevendraaierbatterij repareren
