Ga door naar hoofdinhoud
Bissell SmartClean 1605 Roller Brush Replacement
Wat je nodig hebt
  1. Bissell SmartClean 1605 Roller Brush Replacement, Roller Brush: stap 1, afbeelding 1 van 1
    • Make sure your device is powered off.
  2. Bissell SmartClean 1605 Roller Brush Replacement: stap 2, afbeelding 1 van 1
    • Gently flip device over.
  3. Bissell SmartClean 1605 Roller Brush Replacement: stap 3, afbeelding 1 van 3 Bissell SmartClean 1605 Roller Brush Replacement: stap 3, afbeelding 2 van 3 Bissell SmartClean 1605 Roller Brush Replacement: stap 3, afbeelding 3 van 3
    • Remove plastic plate cover to reveal brush roller.
  4. Bissell SmartClean 1605 Roller Brush Replacement: stap 4, afbeelding 1 van 2 Bissell SmartClean 1605 Roller Brush Replacement: stap 4, afbeelding 2 van 2
    • Remove brush roller from its slots on either side.
    • Apply pressure to one side and pull the roller out of its opposite slot.
    • It's like taking out a spring loaded toilet paper holder.
Conclusie
Austin Maranville
117 Reputatie
1 Handleiding geschreven
Cal Poly, Team S7-G4, Banghart Fall 2017 Lid van Cal Poly, Team S7-G4, Banghart Fall 2017
CPSU-BANGHART-F17S7G4
5 Leden
5 handleidingen geschreven
13 opmerkingen
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
Brian - Antwoord
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
Ryan Beaudre - Antwoord
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
Geoffrey Fraser - Antwoord
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
Mazinger Z - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 1,031
