Ga door naar hoofdinhoud
Bissell Pet Hair Eraser Motherboard Replacement
Wat je nodig hebt
  1. Bissell Pet Hair Eraser Motherboard Replacement, Dirt Cup: stap 1, afbeelding 1 van 2 Bissell Pet Hair Eraser Motherboard Replacement, Dirt Cup: stap 1, afbeelding 2 van 2
    • Firmly grasp the handle and press the release button.
    • Gently pull the dirt cup down and away from the vacuum body.
  2. Bissell Pet Hair Eraser Motherboard Replacement, Power Button: stap 2, afbeelding 1 van 2 Bissell Pet Hair Eraser Motherboard Replacement, Power Button: stap 2, afbeelding 2 van 2
    • Remove the six 1.2 mm Philips #2 screws from the handle and base.
  3. Bissell Pet Hair Eraser Motherboard Replacement: stap 3, afbeelding 1 van 2 Bissell Pet Hair Eraser Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Grasp each half of the body and gently pull apart.
    • The green handle, power button, charge light lens, and dirt cup release are not fastened in place.
    • Once the case is split apart these items may come dislodged.
  4. Bissell Pet Hair Eraser Motherboard Replacement: stap 4, afbeelding 1 van 3 Bissell Pet Hair Eraser Motherboard Replacement: stap 4, afbeelding 2 van 3 Bissell Pet Hair Eraser Motherboard Replacement: stap 4, afbeelding 3 van 3
    • The power button can be removed by gently lifting it off the circuitry.
  5. Bissell Pet Hair Eraser Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 2 Bissell Pet Hair Eraser Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 2
    • Remove the battery plastic hold down by lifting it off the tabs.
    • Remove the battery by lifting straight up.
    • Position the battery aside.
  6. Bissell Pet Hair Eraser Motherboard Replacement: stap 6, afbeelding 1 van 3 Bissell Pet Hair Eraser Motherboard Replacement: stap 6, afbeelding 2 van 3 Bissell Pet Hair Eraser Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Grasp the charger port and remove it by lifting it straight out of the case.
    • Set the charger port next to the battery.
  7. Bissell Pet Hair Eraser Motherboard Replacement: stap 7, afbeelding 1 van 2 Bissell Pet Hair Eraser Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Remove the power button and charge LED light by gently pulling straight out of the case.
    • The vacuum motor can be removed by pulling straight out of the case.
    • All internals are now removed.
    • Set the case halves aside.
  8. Bissell Pet Hair Eraser Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the two 1 mm Phillips #2 screws in the shown locations.
  9. Bissell Pet Hair Eraser Motherboard Replacement: stap 9, afbeelding 1 van 2 Bissell Pet Hair Eraser Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Disconnect the power leads from the vacuum motor.
    • The red power lead goes on the terminal with the visible red dot.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 361
