Inleiding
Make sure to unplug air filter from wall outlet. This step should be a last resort for find any issue dealing with the fan, ionizer or front LED's.
Wat je nodig hebt
Rotate the base counterclockwise, supporting the top with your opposite hand.
Grab the edge of the filter housing and pull the filter away from the rest of the device.
1Gids Commentaar
I knew there were tabs because I could see one but I didn’t know where the others were so I just waited, found your guide, and studied it carefully. Thanks Alexander!
