Ga door naar hoofdinhoud
Bionaire BAP 600 Air Filter Replacement
  1. Bionaire BAP 600 Air Filter Replacement, Base/Intake: stap 1, afbeelding 1 van 1
    • Rotate base counterclockwise, supporting top with opposite hand.
  2. Bionaire BAP 600 Air Filter Replacement: stap 2, afbeelding 1 van 1
    • Pull base away from housing exposing air filter.
  3. Bionaire BAP 600 Air Filter Replacement, Air Filter: stap 3, afbeelding 1 van 1
    • Grab the edge of the filter housing and pull the filter away from the rest of the device.
  4. Bionaire BAP 600 Air Filter Replacement: stap 4, afbeelding 1 van 1
    • Gently pull apart each fold of the filter to check for abrasions or other anomalies. Clean with a dust rag if necessary.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick Miller
167 Reputatie
3 handleidingen geschreven
IUPUI, Team 4-4, Baechle Fall 2016 Lid van IUPUI, Team 4-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S4G4
5 Leden
7 handleidingen geschreven
3 opmerkingen
Bonjour.merci pour le tutoriel,mais où trouver un filtre…
Frederic Battele - Antwoord
Where such a filter can be bought? I was in Italy when I order mine from Amazon (UK) but can't find the filter to replace, I damaged mine.
Any idea?
Nuno Filipe - Antwoord
I been searching for 3 years now. They don't make them. You have to buy a new one. I went to Honeywell and not had a problem.
Blake PS -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 2,444
