Ga door naar hoofdinhoud
Bike Chain Installation
Wat je nodig hebt
  1. Bike Chain Installation, Bike Chain Installation: stap 1, afbeelding 1 van 2 Bike Chain Installation, Bike Chain Installation: stap 1, afbeelding 2 van 2
    • Rout the chain around the front chain rings and rear derailleur.
    • Pull the ends of the chain together.
  2. Bike Chain Installation: stap 2, afbeelding 1 van 2 Bike Chain Installation: stap 2, afbeelding 2 van 2
    • Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case.
    • Caution: Reusing pins in chains can cause the chain to fail. This is because the pins are press fit into link. Using a new pin when assembling a chain is recommend for long term use.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
aaron thielk
1.882 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-13, Maness Fall 2010 Lid van Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Leden
17 handleidingen geschreven
2 opmerkingen
what do you do if the Chain keeps Falling off when your Riding the Bike an the Chain still rubs against the tire .
Anthony - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 60
Altijd: 16,005
