Inleiding
This is a basic step-by-step guide on how to replace handlebar tape on a bicycle. Whether the bar tape on your bike is ripped, worn-out, or just plain missing, this guide will allow you to replace the tape all by yourself!
Wat je nodig hebt
Undo the brake cables holding the brake calipers under tension.
Depress the brake/shift levers (brifters) and insert a 5mm Allen key into the internal bolt. This bolt secures the brifters to the handlebar.
With the 5mm Allen key, loosen and temporarily remove brifters.
Starting on the right side of the handlebar, wrap the new tape around the end in a clockwise direction moving inward.
Using the scissors, cut the tape at an angle towards the outside of the bar.
Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured here)
On the left side of the handlebar, wrap the tape around the end in a counter-clockwise direction moving inward.
Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured).
Één andere persoon heeft deze handleiding voltooid.
