Ga door naar hoofdinhoud
Bicycle Handlebar Tape Replacement
Wat je nodig hebt
  1. Bicycle Handlebar Tape Replacement, Handlebar Tape: stap 1, afbeelding 1 van 3 Bicycle Handlebar Tape Replacement, Handlebar Tape: stap 1, afbeelding 2 van 3 Bicycle Handlebar Tape Replacement, Handlebar Tape: stap 1, afbeelding 3 van 3
    • Undo the brake cables holding the brake calipers under tension.
    • Depress the brake/shift levers (brifters) and insert a 5mm Allen key into the internal bolt. This bolt secures the brifters to the handlebar.
    • With the 5mm Allen key, loosen and temporarily remove brifters.
  2. Bicycle Handlebar Tape Replacement: stap 2, afbeelding 1 van 3 Bicycle Handlebar Tape Replacement: stap 2, afbeelding 2 van 3 Bicycle Handlebar Tape Replacement: stap 2, afbeelding 3 van 3
    • Remove the old tape and discard.
    • Pour some rubbing alcohol on the rag and clean any old adhesive residue off the handlebar.
  3. Bicycle Handlebar Tape Replacement: stap 3, afbeelding 1 van 3 Bicycle Handlebar Tape Replacement: stap 3, afbeelding 2 van 3 Bicycle Handlebar Tape Replacement: stap 3, afbeelding 3 van 3
    • Starting on the right side of the handlebar, wrap the new tape around the end in a clockwise direction moving inward.
    • Be sure to wrap the tape tight, but don't pull so hard that it rips!
    • Using the scissors, cut the tape at an angle towards the outside of the bar.
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured here)
  4. Bicycle Handlebar Tape Replacement: stap 4, afbeelding 1 van 3 Bicycle Handlebar Tape Replacement: stap 4, afbeelding 2 van 3 Bicycle Handlebar Tape Replacement: stap 4, afbeelding 3 van 3
    • On the left side of the handlebar, wrap the tape around the end in a counter-clockwise direction moving inward.
    • Wrap tight, but don't rip!
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured).
  5. Bicycle Handlebar Tape Replacement: stap 5, afbeelding 1 van 2 Bicycle Handlebar Tape Replacement: stap 5, afbeelding 2 van 2
    • Using the 5mm Allen key, reattach and tighten the brifter levers onto the handlebar.
  6. Bicycle Handlebar Tape Replacement: stap 6, afbeelding 1 van 2 Bicycle Handlebar Tape Replacement: stap 6, afbeelding 2 van 2
    • Reattach the brake cables to the brifters and brake calipers
    • Depress the brake levers a couple of times to test and confirm that the cables were reinstalled properly before riding.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Jordan Byrnes
132 Reputatie
1 Handleiding geschreven
UC Davis, Team S1-G70, Coad Spring 2017 Lid van UC Davis, Team S1-G70, Coad Spring 2017
UCD-COAD-S17S1G70
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 17
Altijd: 564
