Ga door naar hoofdinhoud
Besta Super 5000 Keyboard Replacement
Wat je nodig hebt
  1. Besta Super 5000 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Keyboard Replacement: stap 2, afbeelding 1 van 2 Besta Super 5000 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Keyboard Replacement, Back Cover: stap 4, afbeelding 1 van 1
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Keyboard Replacement: stap 6, afbeelding 1 van 2 Besta Super 5000 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
  7. Besta Super 5000 Keyboard Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
  8. Besta Super 5000 Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
  9. Besta Super 5000 Keyboard Replacement: stap 9, afbeelding 1 van 3 Besta Super 5000 Keyboard Replacement: stap 9, afbeelding 2 van 3 Besta Super 5000 Keyboard Replacement: stap 9, afbeelding 3 van 3
    • Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
    • Potential for device damage: Do not yank or remove the ribbon from the device.
    • Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
  10. Besta Super 5000 Keyboard Replacement: stap 10, afbeelding 1 van 2 Besta Super 5000 Keyboard Replacement: stap 10, afbeelding 2 van 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the motherboard with screws still in it because you may damage it.
    • Carefully pry off the motherboard with an opening tool.
  11. Besta Super 5000 Keyboard Replacement: stap 11, afbeelding 1 van 1
    • Take the motherboard out of the body frame.
  12. Besta Super 5000 Keyboard Replacement: stap 12, afbeelding 1 van 2 Besta Super 5000 Keyboard Replacement: stap 12, afbeelding 2 van 2
    • Lift the black keyboard mat off of the motherboard.
    • Replace the motherboard.
  13. Besta Super 5000 Keyboard Replacement, Keyboard: stap 13, afbeelding 1 van 1
    • Replace the old keyboard mat with a new keyboard mat.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sarah
138 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-5, Buehl Fall 2014 Lid van Ohio State, Team 1-5, Buehl Fall 2014
OSU-BUEHL-F14S1G5
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 228
