Inleiding
For Bernina sewing machines that no longer turn on or the sewing machine takes 10 to 60 minutes for it's display and light to illuminate after turning the switch on, the l-board may have a defective capacitor - follow this guide to replace the l-board's D5 capacitor.
Note: for the soldering step, I accidentally had my soldering gun set to 400 and burned through the trace, but there's plenty of room on the board and I was able to add a new wire to link repair the burned trace. Setting your soldering gun to 340 C and using more flux may avoid what I did.
Wat je nodig hebt
Remove the sewing machine's L-Board by removing this screw with a Torx T-20 driver.
Place fingers above and beyond Bear Quilting Patch and pull l-board gently toward you.
Rotate left side of l-board toward you and to the right to access cable.
Gently remove yellow cable.
Remove 4 screws with Torx T-10 driver.
Foreground is the base, pull it toward you and cover (background/closest to table) stays behind.
Base, with l-board attached, is shown in last picture.
Capacitor attached to D5 is bulging out the top and is pushing its innards out the bottom.
If damaged like the one in photograph, obtain a replacement capacitor for D5 that is rated for long-life, 25 volts, and 100 µF, I found one at MicroCenter for $0.99.
Gereedschap gebruikt in deze stap:Tweezers$4.99
I used a soldering gun to wick and to remove as much solder from back side of board where D5 is marked.
After solder is removed, I gently bent the capacitors pins so they were straightened and ready to remove from hole.
Add flux to the board, heat the capacitor's pins, and use a tweezers to pull on the D5 capacitor.
Slide the replacement capacitor into the D5 board holes.
Heat the board and apply solder.
Replacement capacitor looks like pictures to the left.
To reassemble your device, follow these instructions in reverse order beginning with Step 2.
4Gids Commentaar
Do you have pictures of the back of the board? I am trying to find the value for a burnt resistor.
Sadly, I have no more Bernina pics in reserve - it appears I posted everything I had here. Anyone else have a pic to help Willie? If not, I might be able to crack mine open and pull it out to look at the L-board's backside. Oddly enough, I don't remember removing the L-board to do the solder work, but surely I did and it's frustrating I didn't take more pics.
Vous m'avez fait gagner beaucoup de temps. J'ai suivi vos explications, et ma machine est repartie . Super Merci et Bravo;
Right on, Joseph. Thanks for sharing your success with us!
