Inleiding
This guide provides instructions for removing and replacing the gear in the Bendix Magneto: S6RN-23. The Magneto is an elecrical generator that uses magnets to create electrical current pulses. It is often used in ignition systems. A broken gear can stop the Bendix Magneto from rotating, causing incorrect timing of the system. This would cause an engine to either run erraticly or stop altogether.
Wat je nodig hebt
Use a #2 flat head screwdriver to remove the five screws from the body of the Magneto.
7 andere personen hebben deze handleiding voltooid.
