Inleiding
The projector's lamp is key to maintaining optimal image quality, and its periodic replacement is one of the most common tasks associated with owning a projector. All this replacement needs is a single screwdriver and about 5 minutes of your time.
Wat je nodig hebt
Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
Fully remove the top cover in order to get to the lamp housing.
3 andere personen hebben deze handleiding voltooid.
