Inleiding
The Benq HT1075 projector uses a technology called Digital Light Processing (DLP) display, which essentially uses mirrors to output images. The circuit board contains the DLP chip responsible for taking in the digital input and outputting the display. If the board becomes dysfunctional, then the image output would be faulty at best.
Note that the BenQ HT1075 Projector Lamp Replacement is a prerequisite since damage to the lamp is hazardous to both the projector and user.
Wat je nodig hebt
Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
Fully remove the top cover in order to get to the lamp housing.
Turn the projector over and remove the five 9.5 mm Phillips #1 screws that hold the back cover with a Phillips #1 (PH1) screwdriver.
Flip the projector and remove the 6th and last crew.
2 opmerkingen
miss i need to get some information regarding this projector repair. if you can email me, sandarukbio@gmail.com
very good instructions and pictures thank you for your detailed work
