Ga door naar hoofdinhoud
BenQ HT1075 Projector Circuit Board Replacement
Wat je nodig hebt
  1. BenQ HT1075 Projector Circuit Board Replacement, Lamp: stap 1, afbeelding 1 van 1
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Circuit Board Replacement: stap 3, afbeelding 1 van 1
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Circuit Board Replacement: stap 4, afbeelding 1 van 1
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
  5. BenQ HT1075 Projector Circuit Board Replacement, Circuit Board: stap 5, afbeelding 1 van 1
    • Turn the projector over and remove the five 9.5 mm Phillips #1 screws that hold the back cover with a Phillips #1 (PH1) screwdriver.
  6. BenQ HT1075 Projector Circuit Board Replacement, Remove the 6th screw holding the top cover: stap 6, afbeelding 1 van 1
    • Flip the projector and remove the 6th and last crew.
  7. BenQ HT1075 Projector Circuit Board Replacement: stap 7, afbeelding 1 van 1
    • Using an opening tool, remove the top cover by first loosening its top cover.
  8. BenQ HT1075 Projector Circuit Board Replacement: stap 8, afbeelding 1 van 2 BenQ HT1075 Projector Circuit Board Replacement: stap 8, afbeelding 2 van 2
    • Unplug the wire that connects the front cover to the circuit board.
    • Now use the opening tool to pry the front cover from the platform.
    • Gently pull the top cover from the rest of the frame.
  9. BenQ HT1075 Projector Circuit Board Replacement: stap 9, afbeelding 1 van 2 BenQ HT1075 Projector Circuit Board Replacement: stap 9, afbeelding 2 van 2
    • To prevent potential for electrical damage, disconnect any wires connected to the circuit board.
    • Using the opening tool, loosen the sides of the platform. Then gently pull them off from the projector components.
  10. BenQ HT1075 Projector Circuit Board Replacement: stap 10, afbeelding 1 van 3 BenQ HT1075 Projector Circuit Board Replacement: stap 10, afbeelding 2 van 3 BenQ HT1075 Projector Circuit Board Replacement: stap 10, afbeelding 3 van 3
    • Remove these four 8.5 mm Phillips #1 screws using a Phillips #1 (PH1) screwdriver.
    • Afterwards, use a 5mm nut driver to remove the four remaining screws.
    • Use the opening tool to loosen the back cover then pull it off.
  11. BenQ HT1075 Projector Circuit Board Replacement: stap 11, afbeelding 1 van 1
    • With a Phillips #1 (PH1) screwdriver, remove the four 6.3 mm Phillips screws that hold the metal casing on top of the circuit board.
    • Remove the metal casing.
  12. BenQ HT1075 Projector Circuit Board Replacement: stap 12, afbeelding 1 van 2 BenQ HT1075 Projector Circuit Board Replacement: stap 12, afbeelding 2 van 2
    • Using the Phillips #1 (PH1) screwdriver, remove the three 6.3 mm Phillips #1 screws holding down the circuit board.
    • Carefully pull the circuit board from the frame, adding force to the area where the pushbuttons are located.
Conclusie
Gabriela Remulla
912 Reputatie
5 handleidingen geschreven
Cal Poly, Team S6-G1, Banghart Fall 2017 Lid van Cal Poly, Team S6-G1, Banghart Fall 2017
CPSU-BANGHART-F17S6G1
5 Leden
2 opmerkingen
miss i need to get some information regarding this projector repair. if you can email me, sandarukbio@gmail.com
sandarukbio92 - Antwoord
very good instructions and pictures thank you for your detailed work
Quinn Griffith - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 2,224
