Ga door naar hoofdinhoud
Bem Wireless HL2739B Speaker Replacement
Wat je nodig hebt
  1. Bem Wireless HL2739B Speaker Replacement, Speaker Battery: stap 1, afbeelding 1 van 1
    • Peel the rubber cover back from the corner of the speaker to reveal the screw.
    • Repeat for the three remaining corners.
  2. Bem Wireless HL2739B Speaker Replacement: stap 2, afbeelding 1 van 3 Bem Wireless HL2739B Speaker Replacement: stap 2, afbeelding 2 van 3 Bem Wireless HL2739B Speaker Replacement: stap 2, afbeelding 3 van 3
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
  3. Bem Wireless HL2739B Speaker Replacement: stap 3, afbeelding 1 van 1
    • Lift the bottom cover away from the rest of the speaker.
    • There are wires connecting the battery and cover to the rest of the speaker. Be careful when removing the base cover.
    • Using the tweezers, pull the wires from the speaker's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the speaker after this step.
  4. Bem Wireless HL2739B Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using a plastic opening tool, gently pry the battery from the metal base.
  5. Bem Wireless HL2739B Speaker Replacement: stap 5, afbeelding 1 van 1
    • Using tweezers, pull the wires from the metal base connection.
  6. Bem Wireless HL2739B Speaker Replacement, Speaker Motherboard: stap 6, afbeelding 1 van 2 Bem Wireless HL2739B Speaker Replacement, Speaker Motherboard: stap 6, afbeelding 2 van 2
    • Unscrew the four 10mm screws from the motherboard.
  7. Bem Wireless HL2739B Speaker Replacement: stap 7, afbeelding 1 van 2 Bem Wireless HL2739B Speaker Replacement: stap 7, afbeelding 2 van 2
    • Using tweezers, remove the blue/white and red/black wires from motherboard.
  8. Bem Wireless HL2739B Speaker Replacement: stap 8, afbeelding 1 van 2 Bem Wireless HL2739B Speaker Replacement: stap 8, afbeelding 2 van 2
    • Gently re-position the motherboard so you can access the bus wire connected to the speaker.
    • Remove bus wire from the speaker and lift out the motherboard.
  9. Bem Wireless HL2739B Speaker Replacement, Speaker: stap 9, afbeelding 1 van 1
    • Using tweezers remove excess glue that may be covering the screw holes of the speaker's driver.
  10. Bem Wireless HL2739B Speaker Replacement: stap 10, afbeelding 1 van 2 Bem Wireless HL2739B Speaker Replacement: stap 10, afbeelding 2 van 2
    • Remove the four 10mm screws from speaker's base.
  11. Bem Wireless HL2739B Speaker Replacement: stap 11, afbeelding 1 van 2 Bem Wireless HL2739B Speaker Replacement: stap 11, afbeelding 2 van 2
    • Using the metal spudger, pry up on the speaker's base.
    • This will require a moderate amount of force.
    • Pull the wire from the speaker's driver's base from the hole it was in.
  12. Bem Wireless HL2739B Speaker Replacement: stap 12, afbeelding 1 van 2 Bem Wireless HL2739B Speaker Replacement: stap 12, afbeelding 2 van 2
    • Remove the two 5mm screws from the speaker.
    • Lift the driver from the speaker.
Conclusie
Ryan McQueeney
446 Reputatie
4 handleidingen geschreven
USF Tampa, Team S2-G4, Nance Spring 2017 Lid van USF Tampa, Team S2-G4, Nance Spring 2017
USFT-NANCE-S17S2G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 990
