Ga door naar hoofdinhoud
Bem Wireless HL2739B Speaker Battery Replacement
Wat je nodig hebt
  1. Bem Wireless HL2739B Speaker Battery Replacement, Speaker Battery: stap 1, afbeelding 1 van 1
    • Peel the rubber cover back from the corner of the speaker to reveal the screw.
    • Repeat for the three remaining corners.
  2. Bem Wireless HL2739B Speaker Battery Replacement: stap 2, afbeelding 1 van 3 Bem Wireless HL2739B Speaker Battery Replacement: stap 2, afbeelding 2 van 3 Bem Wireless HL2739B Speaker Battery Replacement: stap 2, afbeelding 3 van 3
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
  3. Bem Wireless HL2739B Speaker Battery Replacement: stap 3, afbeelding 1 van 1
    • Lift the bottom cover away from the rest of the speaker.
    • There are wires connecting the battery and cover to the rest of the speaker. Be careful when removing the base cover.
    • Using the tweezers, pull the wires from the speaker's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the speaker after this step.
  4. Bem Wireless HL2739B Speaker Battery Replacement: stap 4, afbeelding 1 van 1
    • Using a plastic opening tool, gently pry the battery from the metal base.
  5. Bem Wireless HL2739B Speaker Battery Replacement: stap 5, afbeelding 1 van 1
    • Using tweezers, pull the wires from the metal base connection.
Conclusie
3 andere personen hebben deze handleiding voltooid.
John Donovan
137 Reputatie
1 Handleiding geschreven
USF Tampa, Team S2-G4, Nance Spring 2017 Lid van USF Tampa, Team S2-G4, Nance Spring 2017
USFT-NANCE-S17S2G4
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 2,428
