Inleiding
Use this guide to systematically disassemble the Bella Cucina Cupcake Maker 13465, manufactured by SENSIO INC. The main components such as the heat fuse, heating elements, LEDs, and wires that make the device function can be observed after the disassembly. Moreover, an electric schematic diagram for the device can be created based on the observations.
The heating elements can become quite hot. Therefore, make sure to unplug the device from the power supply and allow it to sufficiently cool down, before starting the disassembly. Also wear hand gloves, because the metal alloy surfaces can be greasy.
Wat je nodig hebt
Open up the device.
Remove the four 11 mm screws that attach the alloy steel body to the top plastic cover using the Phillips #1 screwdriver.
Remove the plastic cover.
Flip the cupcake maker so that the bottom side faces upwards.
Remove the two adjacent 12 mm screws using a Phillips #2 screwdriver.
Remove the remaining 11 mm screw using a Phillips #2 screwdriver.
Gently remove the case to reveal the space where the main power cable splits into two wires.
Één andere persoon heeft deze handleiding voltooid.
