Ga door naar hoofdinhoud
Bella 4-Slice Toaster Oven Heating Element Replacement
Wat je nodig hebt
  1. Bella 4-Slice Toaster Oven Heating Element Replacement, Outer Shell: stap 1, afbeelding 1 van 1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Heating Element Replacement: stap 2, afbeelding 1 van 1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Heating Element Replacement: stap 3, afbeelding 1 van 1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Heating Element Replacement: stap 4, afbeelding 1 van 1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Heating Element Replacement: stap 5, afbeelding 1 van 1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Heating Element Replacement: stap 6, afbeelding 1 van 1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Heating Element Replacement: stap 7, afbeelding 1 van 1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Heating Element Replacement: stap 8, afbeelding 1 van 1
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Heating Element Replacement, Heating Element: stap 9, afbeelding 1 van 1
    • Remove the red wire from the heating element.
  10. Bella 4-Slice Toaster Oven Heating Element Replacement: stap 10, afbeelding 1 van 1
    • Remove white wire from the opposite side of the heating element.
  11. Bella 4-Slice Toaster Oven Heating Element Replacement: stap 11, afbeelding 1 van 1
    • Use a metal spudger to unfold the tabs of metal that hold heating element in place.
  12. Bella 4-Slice Toaster Oven Heating Element Replacement: stap 12, afbeelding 1 van 3 Bella 4-Slice Toaster Oven Heating Element Replacement: stap 12, afbeelding 2 van 3 Bella 4-Slice Toaster Oven Heating Element Replacement: stap 12, afbeelding 3 van 3
    • Gently push the heating element from the side with the red wire to remove it from the toaster.
  13. Bella 4-Slice Toaster Oven Heating Element Replacement: stap 13, afbeelding 1 van 1
    • Repeat steps 1-4 for the second heating element.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 48
Altijd: 1,905
