Ga door naar hoofdinhoud
Bell and Howell DNV16HDZ LED Replacement
Wat je nodig hebt
  1. Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: stap 1, afbeelding 1 van 2 Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: stap 1, afbeelding 2 van 2
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ LED Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ LED Replacement: stap 3, afbeelding 1 van 1
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ LED Replacement, LED: stap 4, afbeelding 1 van 1
    • Take out the two 20 mm Phillips #0 screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ LED Replacement: stap 5, afbeelding 1 van 3 Bell and Howell DNV16HDZ LED Replacement: stap 5, afbeelding 2 van 3 Bell and Howell DNV16HDZ LED Replacement: stap 5, afbeelding 3 van 3
    • The two 30 mm Phillips #0 screws left can be removed to gain access to the circuit board along with the LED.
    • From here we can pop out the LED using the wedge or your fingers if you can manage it.
Conclusie
Donald Desrosier
101 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 8-4, Botvin Spring 2016 Lid van UMass Dartmouth, Team 8-4, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G4
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 300
