Inleiding
This guide walks you through how to replace the switch cover on the NetCam.
Wat je nodig hebt
Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
Carefully use your fingers to gently pull out the white attachment from the tan colored part.
Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
Één andere persoon heeft deze handleiding voltooid.
