Inleiding
This guide will walk you through how to replace the whole circuit board on the NetCam.
Wat je nodig hebt
Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
Use tweezers to gently pull out the white attachment from the port.
Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
Flip the circuit board to the back side.
Fold down the tape with your finger.
With the Phillips #0 screwdriver, unscrew the two 1.2 mm screws.
On the back of the board pull the switch slowly upward to take it off.
Één andere persoon heeft deze handleiding voltooid.
