Inleiding
This is an easy to follow guide (for beginners) that will help you replace the blue buttons in the remote control of your Beiens Cartoon RC Race Car. This replacement may be needed if buttons are dirty or broken. For this replacement you will need a Phillips #00 screwdriver. There is a choking hazard with the six 6.5 mm screws from the remote, so it is better to do this repair without young children or pets present.
Wat je nodig hebt
Hold the remote control with the backside facing you, and using the Phillips #00 screwdriver, unscrew the six 6.5 mm screws on the back of the controller that holds the remote together.
Remove the back side of remote.
