Inleiding
Use this guide to remove and replace the power cord from the power lead connector. It will show you how to split the lower handle housing to gain access to the power lead connector and other internal components. The lower handle housing must be split in order to replace the power cord without damaging it.
Wat je nodig hebt
Unlock the handle of your Deep Waver to gain access to the screws you need to remove.
Remove two 10 mm Phillips #01 screws from the lower handle housing.
Remove one 10 mm Phillips #02 screw from the lower handle housing.
Pull upward on the power cord connector to remove it from the lower handle housing.
To reassemble your device, follow these instructions in reverse order. Once each half of the housing have been put back together, install a new Housing Retainer to replace the one you cut off.
