Ga door naar hoofdinhoud
Beboncool Gamepad for Nintendo Switch Charging Port Replacement
Wat je nodig hebt
  1. Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: stap 1, afbeelding 1 van 3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: stap 1, afbeelding 2 van 3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: stap 1, afbeelding 3 van 3
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 2, afbeelding 1 van 2 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 2, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 3, afbeelding 1 van 3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 3, afbeelding 2 van 3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 3, afbeelding 3 van 3
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 4, afbeelding 1 van 2 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 4, afbeelding 2 van 2
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 5, afbeelding 1 van 2 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 5, afbeelding 2 van 2
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 6, afbeelding 1 van 2 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 6, afbeelding 2 van 2
    • Gently pull the battery from the circuit board, leaving it connected to the board with its lead wires.
  7. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 7, afbeelding 1 van 3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 7, afbeelding 2 van 3 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: stap 7, afbeelding 3 van 3
    • Remove the charging port from the edge of the motherboard by desoldering each of its four solder points and lifting the port from the board.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 22
Altijd: 681
