Inleiding
This guide will show you how to replace the side panel on your Beats Solo Pro
Wat je nodig hebt
Once extended insert a prying the new gap to unclip the panel
Once unclipped repeat on the other side of the panel
The two clips are towards the top of the panel, as indicated by the location of the metal prying tool in the image.
Slide the panel down and lift away from the headphone just until its separated
If needed tighten the PH00 screw(if your side panel has came loose on it own you will need to do this to fix the issue)
To reassemble complete steps in reverse:-)
4 andere personen hebben deze handleiding voltooid.
Één opmerking
Muchas gracias por tus pasos a seguir.
Yo tengo un problema pero con el tornillo que esta tapado por los cables, al cual no puedo acceder para poderlo apretar contra la tapa exterior.
