Ga door naar hoofdinhoud
Beats Solo HD Headband Replacement
Wat je nodig hebt
  1. Beats Solo HD Headband Replacement, Headband: stap 1, afbeelding 1 van 2 Beats Solo HD Headband Replacement, Headband: stap 1, afbeelding 2 van 2
    • Unscrew both screws in the metal brace using a T4 Torx screwdriver.
    • Repeat all steps on both the right and left sides of the headphones.
  2. Beats Solo HD Headband Replacement: stap 2, afbeelding 1 van 3 Beats Solo HD Headband Replacement: stap 2, afbeelding 2 van 3 Beats Solo HD Headband Replacement: stap 2, afbeelding 3 van 3
    • Lift away the metal brace and set it aside.
    • Be sure to keep the small plastic spacers located underneath the brace on either side. They may fall out when removing the brace.
  3. Beats Solo HD Headband Replacement: stap 3, afbeelding 1 van 3 Beats Solo HD Headband Replacement: stap 3, afbeelding 2 van 3 Beats Solo HD Headband Replacement: stap 3, afbeelding 3 van 3
    • Pry off each clip on the headband cushion until it is loose enough to be removed.
    • Start by prying off the clips on either end, since they are easier to detach. Finish with the clips in the middle.
  4. Beats Solo HD Headband Replacement: stap 4, afbeelding 1 van 3 Beats Solo HD Headband Replacement: stap 4, afbeelding 2 van 3 Beats Solo HD Headband Replacement: stap 4, afbeelding 3 van 3
    • Slide the gray plastic covering away from the hinge to remove it.
  5. Beats Solo HD Headband Replacement: stap 5, afbeelding 1 van 1
    • Grasp the earpiece with one hand and bend the headphones at the hinge.
    • Brace the headband by pressing it downward against the surface you are working on.
    • These steps will prepare you to pry off the hinges, so make sure your hold on the headphones is stable.
  6. Beats Solo HD Headband Replacement: stap 6, afbeelding 1 van 1
    • Slide the Jimmy between the metal earpiece and the plastic of the headband at the hinge.
  7. Beats Solo HD Headband Replacement: stap 7, afbeelding 1 van 1
    • Pry the plastic away from the metal earpiece using an opening tool until one of the small cylindrical hinge pins can be removed.
    • This may be difficult, as prying takes some force. You may need to experiment and try whatever tools or prying techniques work best for you.
  8. Beats Solo HD Headband Replacement: stap 8, afbeelding 1 van 3 Beats Solo HD Headband Replacement: stap 8, afbeelding 2 van 3 Beats Solo HD Headband Replacement: stap 8, afbeelding 3 van 3
    • Pull the earpiece out of the headband.
  9. Beats Solo HD Headband Replacement: stap 9, afbeelding 1 van 2 Beats Solo HD Headband Replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the second hinge pin with precision tweezers and set it aside.
  10. Beats Solo HD Headband Replacement: stap 10, afbeelding 1 van 2 Beats Solo HD Headband Replacement: stap 10, afbeelding 2 van 2
    • Insert one of the hinge pins into one of the sockets of the new headband.
    • Press the hinge of the earpieces into the new headband by aligning it with the pin.
  11. Beats Solo HD Headband Replacement: stap 11, afbeelding 1 van 3 Beats Solo HD Headband Replacement: stap 11, afbeelding 2 van 3 Beats Solo HD Headband Replacement: stap 11, afbeelding 3 van 3
    • Insert the second pin into the other socket of the headband using precision tweezers.
    • Squeeze the pin inwards if the hinge seems loose or if the pin is jutting out of the socket.
  12. Beats Solo HD Headband Replacement: stap 12, afbeelding 1 van 3 Beats Solo HD Headband Replacement: stap 12, afbeelding 2 van 3 Beats Solo HD Headband Replacement: stap 12, afbeelding 3 van 3
    • Slide the gray plastic covers back onto the headband.
    • Pressing the white wire against the back of the headband can help to avoid damage during reassembly.
  13. Beats Solo HD Headband Replacement: stap 13, afbeelding 1 van 3 Beats Solo HD Headband Replacement: stap 13, afbeelding 2 van 3 Beats Solo HD Headband Replacement: stap 13, afbeelding 3 van 3
    • Lay the metal brace in place.
    • If the small plastic spacers are loose, it may be helpful to place them down before the brace.
  14. Beats Solo HD Headband Replacement: stap 14, afbeelding 1 van 2 Beats Solo HD Headband Replacement: stap 14, afbeelding 2 van 2
    • Screw both screws back into the metal brace.
  15. Beats Solo HD Headband Replacement: stap 15, afbeelding 1 van 3 Beats Solo HD Headband Replacement: stap 15, afbeelding 2 van 3 Beats Solo HD Headband Replacement: stap 15, afbeelding 3 van 3
    • Reattach the headband cushion by pressing each clip into place.
Conclusie
When your replacement is finished, all parts other than the old headband should be reattached to the headphones. If needed, bend your headphones at the hinges to ensure they are properly attached. If there is some difficulty bending, the hinge pins may need to be pushed further in until they are secure. If the hinges on both sides bend without problem and all of the parts are reassembled, your replacement is done.
Erica Mota
241 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 67
Altijd: 1,729
