Inleiding
This repair is for when the right side of the headset does not work but the left side still works. The wire breaks from the hinges repeated movement over time. Please make sure to get a 1mm thick wire for the replacement so it will fit properly. Suggested part search terms: "Solo 2 HD internal wire".
Wat je nodig hebt
Pull out the wire from the beats. The wire is a jack wire and requires nothing special to remove.
8 andere personen hebben deze handleiding voltooid.
