Inleiding
In this guide, the process of speaker replacement is shown.
Wat je nodig hebt
Using a plastic opening tool, pry the casing from the rest of the device.
Pry all the way around the edge and then pull apart.
Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
Hola amigos y amigas como estan me pueden ayudar como puedo conseguier la placa del beatspill esta q esta aki xf urgente soy de Ecuador ciudad manta
Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
After completing the guide for removing the case, remove the cables connecting the speakers.
Simply pull up on them without pulling on the wires themselves.
While holding the case with one hand, pull up on the speaker you wish to replace.
5 opmerkingen
Where can I find replacement speakers?
Please
Where can I find the replacement speakers..??
