Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using a plastic opening tool, pry the casing from the rest of the device.
Pry all the way around the edge and then pull apart.
Using your thumb, remove the 8 rubber plugs in order to get to the screws.
Simply rub them towards the speakers and they will slide out enough to grip the edge and pull them out.
Using a Phillips #2 screwdriver, remove the 8 (10mm maxi-loc Phillips #2) screws that hold the casing together.
Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
After completing the guide for removing the case, remove the cables connecting the speakers.
Simply pull up on them without pulling on the wires themselves.
Set the half of the device containing speakers to the side.
Remove all five remaining connectors on the motherboard.
Remove the chip for the Bluetooth antenna located to the top right of the motherboard.
Using a Phillips #2 screwdriver, unscrew the 4 (8mm pan head Phillips #2) screws holding the motherboard onto the case. They are located in the four corners of the board.
Using both hands, gently lift the motherboard from the case.
You have successfully removed the motherboard.
14 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Disculpe la molestia quisiera saber el número de parte de los transistores Q2,Q3
I have a question regarding the contents of circuit.
which type of IC is used in the circuit which is hided by a marker. And if you have that ic than how can i contact you.
I need the Beats Pill XL Motherboard.. where i can buy
Bonjour impeccable bien expliqué
Ou puis-je trouvé cette carte
Merci beaucoup
0967197831 este es mi movil nesecito saber cuanto cuesta la placa de este beatspill xf ayudeme
