Inleiding
For general disassembly guide follow this link. This guide will follow the steps taken in the general disassembly of the Beats Pill 1.0.
Using the spudger, create space between the speaker covers and then remove.
On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
Using a ESD-safe Philips #0 Screwdriver, remove the four screws that were underneath the rubber stand.
Remove the two Philips #0 screws with the ESD-safe screwdriver.
Slowly remove the center band and 2 clip rings until the adhesive separates.
Using the spudger, starting in the middle, pry the device apart along itās seam as circled in red.
Open the device to separate the two main bodies of the device. The device should look as picture number 3.
Remove the speaker wire(yellow, red, black, white) from the mother board.
Using a Phillips #0 Screwdriver, unscrew the four screws holding the bands that go over the battery.
Using the same screwdriver, remove the motherboard screws along with the rubber stoppers.
Gently remove the motherboard from the case
Remove the yellow NFC module with Tweezers
Using a soldering iron attach the new battery to the motherboard with the red wire connecting to the 0.2 volts (+) and black wire connecting to the ground (-). See the soldering guide for more information on how to perform this step.
26 andere personen hebben deze handleiding voltooid.
8 Opmerkingen
I got a replacement battery for 2.0 from Amazon, it works great! here is the link:
https://www.amazon.com/dp/B072PHZ235
And it also has battery for pill 1.0, pill XL...
Jailene -
Could you please tell what is the yellow card in the last picture?
Looks like the Bluetooth antenna
