Ga door naar hoofdinhoud
Beats Mixr Headband Replacement
Wat je nodig hebt
  1. Beats Mixr Headband Replacement, Remove the caps on the headband: stap 1, afbeelding 1 van 1
    • Use a spudger or prying tool to remove the cap on both sides of the headband by applying pressure where the cap meets the band. Next, you will need a Phillips head #00 screwdriver to remove the screws and washer. Twist the screwdriver into the screw and pull it apart from the washer when it becomes loose.
  2. Beats Mixr Headband Replacement, Separate the ear cuff from the headband.: stap 2, afbeelding 1 van 1
    • Begin by pulling the two parts of the headband away from each other slowly and make sure not to break any wires. The wires will now slide free of the headband.
Conclusie
29 andere personen hebben deze handleiding voltooid.
Allie Horton
929 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-11, Donnelly Fall 2014 Lid van USF Tampa, Team 1-11, Donnelly Fall 2014
USFT-DONNELLY-F14S1G11
1 Lid
3 handleidingen geschreven
3 opmerkingen
Started to disassemble my Mixr. After removing the covers I found the screws not so easy to remove as stated. For one, they must have used lock tite. In addition the nut and screw are so tight a screw driver will not work. Mine has spanner type nuts. I need to find a wrench that will fit.
Has anyone ran into this.
Robert Schumann - Antwoord
Did you figure out how to get the screws out without breaking?
simmons4jesus -
The replacement parts listed are for studio not mixr and the colors dont match!
Missy Truth - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 39
Altijd: 14,418
